Andrew Hamilton Watts Posted September 27, 2022 Share Posted September 27, 2022 (edited) Hello, Reaching out with a question about this light (whiteish) line that appears on the top of the frame (about where the underline is). It appears on every frame, obviously most clear in areas that are darker. I have also noticed it in the bottom right corner as well, but not as bad. I am wondering if anyone had an idea or guess as to what this might be? Is it a registration issue or something with the pressure plate? The camera is a Rex 1, shot with a 25mm on 250D. Thanks, Andrew Edit: sorry it is hard to see, I couldn't upload a large enough image. Edited September 27, 2022 by Andrew Hamilton Watts mistake Link to comment Share on other sites More sharing options...
Premium Member David Mullen ASC Posted September 27, 2022 Premium Member Share Posted September 27, 2022 Looks like the edge of the gate is reflecting the white clouds? Link to comment Share on other sites More sharing options...
Andrew Hamilton Watts Posted September 27, 2022 Author Share Posted September 27, 2022 32 minutes ago, David Mullen ASC said: Looks like the edge of the gate is reflecting the white clouds? I had wondered that as well, but it appears on frames that are not clouds, perhaps that was not the best example to grab an image from. Link to comment Share on other sites More sharing options...
Premium Member Dom Jaeger Posted September 28, 2022 Premium Member Share Posted September 28, 2022 Has someone filed the bottom of the gate? Normally you would have a thicker frameline.. Because lenses invert the image, the top of the image is at the bottom of the gate in camera. Link to comment Share on other sites More sharing options...
Andrew Hamilton Watts Posted September 28, 2022 Author Share Posted September 28, 2022 14 hours ago, Dom Jaeger said: Has someone filed the bottom of the gate? Normally you would have a thicker frameline.. Because lenses invert the image, the top of the image is at the bottom of the gate in camera. That is an interesting question, I cannot say for sure. I know the camera had been previously CLA'd, but unsure if there was any work done on the gate. Why would someone file the gate? and if so, could that be the cause of this phantom white line for some reason? Link to comment Share on other sites More sharing options...
Premium Member Dom Jaeger Posted September 29, 2022 Premium Member Share Posted September 29, 2022 8 hours ago, Andrew Hamilton Watts said: Why would someone file the gate? I just noticed that there's barely any frameline between the frames in your example, but it's probably just light bleeding across because it's a bright image. At any rate, maybe just check that the edges of the gate aperture aren't shiny bare aluminium. If necessary, you can blacken them with a bit of matte black touch-up paint. 1 Link to comment Share on other sites More sharing options...
Robert Hart Posted September 30, 2022 Share Posted September 30, 2022 Untidy fillets in the frame corners suggest some intervention may have occurred. Maybe somebody was minded to tidy up what may have been perceived as apparent roughness in the metal finish at the frame edges. As suggested in previous replies, blackening the inner surfaces of the frame edges may help if those edges are shiny bare metal. With such a thin border between frames some crossover flaring remains likely to occur due to internal reflection within the film itself. The remjet backing on film can only do so much. 1 Link to comment Share on other sites More sharing options...
