Some Canon Scoopic + 500T nighttime stills
Kevin Neal
 Share
Thought I’d share some stills from a recent music video shoot. Shot on an ultra 16 modified Canon scoopic & only available light. All 500T pushed 1 stop. Not final color grade, just my quick adjustments in resolve.
Higher res stills: https://drive.google.com/drive/folders/10LWsp72Wvi8Eu3_x4U6DvWFkVzoA1Xoe
AA39126-C-6624-4-C73-95-AF-DE8-E2-E9-B99
EBF79634-ACF0-461-A-9-AD3-11-E17-ED28-D4
8-C0-CC584-F760-4702-967-B-98-D02-CF35-E
948-D19-B3-549-C-47-E6-90-A9-E8-D9-EFEC0
02-CD2350-8-DAF-4993-BEA4-025-F71-BEAB15
9325-C913-59-AF-40-B6-AF72-DBBFF8-A67-B8
Edited by Kevin Neal
Add link
Link to comment
  • 2 months later...
  • 1 month later...
On 9/1/2021 at 12:51 PM, Rick Kleeßen said:
Hey Kevin!
I also own a Scoopic. Could you explain what means ultra 16 modified?
greetings - Rick
Raaf nailed it. It's close to S16 without any recentering needed.
On 9/2/2021 at 11:04 PM, Raaf Sundquist said:
Kevin,
The shots look good for available light - what lens/aperture did you use?
-- Raaf
The scoopic has a fixed lens & then I used the canon wide angle adapter for some shots.
Was super run & gun so stayed around f4-5.6 most of the time to give myself some dof leeway, and then a couple (like that smoking shot w/ bokeh) are wide open. 500T pushed a stop is incredible when paired w/ good scan.
Link to comment
  • Sustaining Member
The Scoopic lens is really amazing...I've had colorists ask me what lens I was using because it was so sharp. The whole "zoom in for critical focus" is very easy with a Scoopic as well which helps. Very easy and efficient camera...especially for loading.
Link to comment
  • 1 month later...
  • Sustaining Member
On 10/12/2021 at 2:12 AM, Jon O'Brien said:
Hi Will, which model of Scoopic is best in your opinion? Thanks for any advice.
Sorry I just saw this!
Scoopic MS lets you add a 400' magazine if you can find the adapter so I usually recommend that but I've had an M, MN & MS and they all shoot the same as far as I can tell so if you get a good deal on any of them...go for it.
I look at Scoopics as having the ease and convenience of Super 8 if you want...even the loading is the easier in any non-cartridge 16mm camera...but you can turn off the autoexposure and use your own meter as you want. The lens is just great. I have seen them removed from Scoopics and mounts put on them for use in other cameras actually.
Best part of a Scoopic is not having to constantly wind the camera. Can't tell you how that would hurt my hand after a half day of shooting. Then the autoloading and autoexposure are close seconds. It all adds up to ACTUALLY USING THE CAMERA more.
If you're shooting a feature then grab an Arri SR2 or 3 but for music videos, home movies and fun can't beat a Scoopic.
  • Upvote 1
Link to comment
Thanks Will! Good to know. The winding of spring-wound cameras doesn't bother me too much, as long as the turret if there is one isn't swung out to the side. Even with a Rex-O-Fader in place on a Bolex, which lifts the wind handle off the camera body a bit higher and gets it almost out of the way of the turret, I find it all just a bit too fiddly and frustrating, doing it multiple time during a shoot.
Link to comment
Some people with Scoopics say that they've noticed a bit of image flicker occasionally. Have you ever seen this in your footage Will? Just the other day I came across a post by someone who said that flicker is caused by a light leak. I've heard it said that Scoopics have a strip of foam around the door or lid of the film compartment and that this sometimes has deteriorated and needs replacing.
Link to comment
I use just the winding handle from the Rex O Fader sans mounting the Rex o Fader on the camera to achieve that stand off room
Link to comment
Guest
Reply to this topic...
  Only 75 emoji are allowed.
 Share
Forum Sponsors
FJS International
Film Gears
DMX-iT
Cinematography Books and Gear
