Boris Kalaidjiev Posted August 3 Share Posted August 3 Hello, I am wondering how this was done? I believe or would like to believe that it was done in camera. I think the photographer used some sort of prism, glass in front of the lens but I am curious as to what type? I know there are kaleidoscope type of filter glass that you can play around with in front of the lens but the effect here is done a lot more subtler than that. Any ideas as to what sort of glass was used or what I should start to play around with to get a similar effect (maybe break my grandmothers old chandelier and see how that looks in front of the lens haha)? Thanks! P.S the photographer has some really good work you can check her out on IG @xenichez Quote Link to comment Share on other sites More sharing options...
Boris Kalaidjiev Posted August 3 Author Share Posted August 3 Quote Link to comment Share on other sites More sharing options...
Premium Member Dan Finlayson Posted August 3 Premium Member Share Posted August 3 (edited) This is absolutely a prism. It could be something the photographer found, like grandma's chandelier, or it could have been something purpose built for photography. There's a company based in Arizona called Prism Lens FX that produce a variety of interesting gadgets to throw in front of your lens. Here's a link to their site, directly to the product most similar to the effect in these photos. I love the handheld diopter they produce - I've used the effect for years but with standard diopters it's a pain. They make one with a handle just like the half prism I linked to that makes manipulating the image way easier. Edited August 3 by Dan Finlayson Quote Link to comment Share on other sites More sharing options...
Boris Kalaidjiev Posted August 3 Author Share Posted August 3 Hi Dan, Yeah I know about Prism Lens FX but I sort of thing it’s not with they’re hand held diopter or kaleidoscope. I feel that hers are a bit more subtle in a way. Any other ideas or suggestions? ive been thinking of going to a glass shop and asking them if they can custom create glass with different thicknesses. For ex a piece of glass that’s 10x4cm and on one end the glass is 1,2mm thick and on the other end it is 5,6mm with a bit of a curvature (to have a lens effect). Something similar to the kaleidoscope effect but simpler. Quote Link to comment Share on other sites More sharing options...
Premium Member Phil Rhodes Posted August 3 Premium Member Share Posted August 3 Spare chandelier parts! http://www.uk.thechandeliercompany.com/section.php/911/1/crystal-and-glass-pieces Quote Link to comment Share on other sites More sharing options...
Kyryll Sobolev Posted August 3 Share Posted August 3 i worked with DPs who had the prism and broken glass set that they have purchased and collected over the years it's probably trial & error until you find what you think works for you 1 Quote Link to comment Share on other sites More sharing options...
Premium Member Phil Rhodes Posted August 3 Premium Member Share Posted August 3 Or hit the charity shops* for old bits of cut glass tableware. * Thrift stores, Americans 2 Quote Link to comment Share on other sites More sharing options...
Premium Member Dan Finlayson Posted August 4 Premium Member Share Posted August 4 10 hours ago, Boris Kalaidjiev said: Yeah I know about Prism Lens FX but I sort of thing it’s not with they’re hand held diopter or kaleidoscope. I feel that hers are a bit more subtle in a way. I guess keep in mind that focal length has a huge impact on how pronounced the effect is per prism. Quote Link to comment Share on other sites More sharing options...
Boris Kalaidjiev Posted August 4 Author Share Posted August 4 @Kyryll Sobolev That is so overwhelming, so much glass in front haha. @Dan Finlayson That was the other thing that I was going to say. If you have a widish lens 16, 20mm and a matte box you will need a lot bigger pieces of glass in order to cover bigger parts of the frame. So i think the chandelier spare parts might not work as well for wide lenses with matte boxes. Quote Link to comment Share on other sites More sharing options...
Premium Member Dan Finlayson Posted August 4 Premium Member Share Posted August 4 11 minutes ago, Boris Kalaidjiev said: So i think the chandelier spare parts might not work as well for wide lenses with matte boxes. Agreed. I don't see much need for a proper mattebox when doing this sort of thing though. Worst case, tape the ND to the front of the lens. This is also why I recommended that very large, handheld split prism - way easier to get the coverage over the frame with the wider lenses Quote Link to comment Share on other sites More sharing options...
