Carl Looper Posted November 26, 2022 Posted November 26, 2022 12 minutes ago, Robert Houllahan said: The data is stored in log format, directly corresponding to density of the original negative. Since the scanned material is likely a negative, the data can be said to be "gamma with log encoding". There is no suggestion in the posted description of cineon encoding that positives (as distinct from negatives) would be encoded in linear rather than log. Be it the density of negatives or the density of positives, density is defined as the log of reciripical transmittance. Why log encoding? Because, per bit, log encoding is more accurate than linear encoding. There is a claim that positives are encoded in terms of linear values. This may very well be true, but there is nothing in the posted description of cineon to suggest this is the case. So why post it? DPX (based on Cineon) supports both linear and log encoding (among others) so its not out of the question that DPX encoding of positives might be done in linear format. Either way it would be good to know what the actual practice is. By way of analogy, it would be good to know whether a list of numbers representing distances were provided in millimeters or inches.
Site Sponsor Robert Houllahan Posted November 27, 2022 Site Sponsor Posted November 27, 2022 12 hours ago, Carl Looper said: There is no suggestion in the posted description of cineon encoding that positives (as distinct from negatives) would be encoded in linear rather than log. Actually it is pretty clear that negatives are scanned with (gamma cineon log) and that prints do not have that curve applied. IDK if you think you are somehow magically reinventing the wheel here but since Kodak's Cineon data scanning was invented in the early 1990's hundreds (or thousands) of billions of feet of film has been scanned with 99.99997% of all prints and other positives like Reversals being scanned as linear data with the 00.000038% having been scanned (somehow) as Log because some scanner op made a mistake. There is nothing new here this ground has been covered and re-covered and run over by artillery horses then model Ts then Chevys then Land Cruisers and tanks then horses again and a few HumVees and then a pack of dogs then followed by crows and a herd of cats. This conversation is moot. 1
Larry Baum Posted January 19, 2023 Author Posted January 19, 2023 Sorry I've been out of my own thread for a while. I've received more files (my original samples were all 5K and my new ones were mostly full 6.5K with a few 5K for additional comparison). I also got a little bit of an IT8 chart scanned. In the end it seems that full 6.5K scans from it ARE stored in some wide gamut format (contrary to the totally incorrect metadata which claims something similar to REC709 primaries). It's something weird though. Vaguely like P3, but definitely not P3. It means that you need to painstakingly feed it calibration charts and try to build a LUT or manually adjust primary locations by eye until the data matches what is on the 35mm prints. Kind of weird, the files really should have metadata that lists what primaries they are stored as! What is the point of making someone spend endless hours trying to say tune up adjustments to the primaries in Adobe ACR compared to what the metadata falsely claims they are? Or spend time trying to build some program to make a custom LUT out of chart data and so on. Sure you may need to fine tune to adjust how the scanner sees a certain stock or this or that but we are not talking about that but simply finding out what format the data itself is stored in reference too. Yeah, DSLR makers don't give you the proper metadata for the primaries of the RAW output of the cameras which is silly too but at least there the big stills processing software companies all test the sensors and figure it out and provide a RAW interpretation file for each camera model. It doesn't seem any of them do that for things as esoteric as motion picture film scanners. Now whether or not these stored in reference to some custom wide gamut format 6.5K scans actually store any wide gamut colors or the engine actually clips them down first and then stores the data is not yet known for sure yet. So far it seems a little suspicious that things seem to stay within REC709 triangle for the most part (and what doesn't might possible just be getting pushed beyond by grading choices). But then I may not have the proper stuff scanned yet, maybe the DI were done in REC709 before printout to film, not sure. So whether the scans can ever actually ever contain any colors beyond REC709 or not, as motion picture print film certainly can, not yet sure, but the data format CAN hold such colors though, contrary to my initial claims, BUT that is only because the new scans are full 6.5K scans and these seem to use a different reference for the data than any sub-6.5K scans from the Scanstation do. So, as just mentioned, on the other hand any scans done under the native 6.5K seem to NOT be stored in a wide gamut format, but some regular gamut format. It's vaguely like REC709 gamut, the saturation is about the same, but the primaries seem a bit off, they almost seem to have the same hue as for the full scans and yet the saturation remapped to be something like REC709/sRGB, kind of odd, not sure if that is a bug or not. It definitely doesn't seem capable of storing any colors beyond REC709 (beyond maybe a little twist) in the data format used for the 5K and under scans (which is what my original samples were done in). So it is seeming like I was correct and not correct. The scans 5K and under, which my original demo samples were, do NOT appear to allow for wide gamut color and seem remapped to REC709 max saturation (although with an odd twist to certain colors, almost like they left the primaries hues in some wide gamut format). But it seems that once you do full 6.5K scans that suddenly the data is stored in reference to a different color gamut, one that is definitely stored with saturation levels that seem more like something wide gamut, maybe vaguely along the lines of something could allow for P3-ish levels or just a bit less max saturation. Tentatively, the blue primary seems quite different from P3 though in particular. In the end it seems that full 6.5K scans from it ARE stored in some wide gamut format (contrary to the totally incorrect metadata). It's something weird though. Vaguely like P3, but definitely not P3. It means that you need to painstakingly feed it calibration charts and try to build a LUT or manually adjust primary locations by eye until the data matches what is on the 35mm prints. Kind of weird, the files really should have metadata that lists what primaries they are stored as. Whether they actually ever contain any colors beyond REC709 or not, not yet sure, the data format can hold such colors though. On the other hand any scans done under the native 6.5K seem to NOT be stored in a wide gamut format, but some regular gamut format. It's vaguely like REC709 gamut, the saturation is about the same, but the primaries seem a bit off, they almost seem to have the same hue as for the full scans and yet the saturation remapped to be something like REC709/sRGB, kind of odd, not sure if that is a bug or not. It definitely doesn't seem capable of storing any colors beyond REC709 (beyond maybe a little twist) in the data format used for the 5K and under scans (which is what my original samples were done in).
Larry Baum Posted January 19, 2023 Author Posted January 19, 2023 More simply since my last post I have received some 6.5K scans in addition to my initial 5K demo scans: It seems that 6.5K scan mode has data stored in reference to some wide gamut format that probably could hold most colors film is capable of while any scans it does below 6.5K seem to be full re-mapped to a non-wide gamut format that seems like it would have to clip some colors film is capable of. It seems the metadata for color gamut is totally utterly wrong for ALL format outputs from the Scanstation at 6.5K and somewhat wrong for ALL output formats from Scanstation under 6.5K. Sub 6.5K stuff will load into Resolve automatically as REC709 and look kinda OK, but on close examination some colors are twisted, reds go orange, you get wrong relatively color balance, it can NOT be correct by color temp or tint or most normal color controls, you need to do more advanced adjustments like adjusting primary locations or use custom LUTs. It certainly seems like it would clip or remap down wider gamut colors that film can produce. The data does not seem to be set up to be able to handle wide gamut colors. 6.5K stuff loads in Resolve and ACR looking all dull and weird, since it is treated as something close to REC709 gamut but it is not at all REC709 gamut, metadata utterly wrong. To get proper colors it seems you must do extensive calibration adjustments to Adobe ACR primary locations or feed custom built LUTs into other programs so the data can be interpreted in the format that it is actually stored in which seems to be some custom moderately wide gamut format. These 6.5K scans might contain all colors 35mm film has or might not, the data certainly allows for it, whether it does or still gets clipped, not sure yet.
Larry Baum Posted January 19, 2023 Author Posted January 19, 2023 opps OK even more simply hah: 6.5K scans actually do seem to be stored in a format that allows for wide gamut colors any scan under 6.5K does NOT seem to be stored in a format that allows for wide gamut colors (all my sample scans when I was first posting here were under 6.5K) it is not yet know whether the 6.5 scans actually deliver any wide gamut colors, although the data format would make it possible the metadata for color gamut seems to be somewhat wrong for all files scanned under 6.5K and utterly wrong for all files scanned at 6.5K, it tells you totally wrong info for programs on how to interpretate the colors so you need to RADICALLY custom adjust the primary locations in programs like ACR or use color charts and special software to build up LUTs, not sure why they don't give proper metadata
Larry Baum Posted January 19, 2023 Author Posted January 19, 2023 At least that is what appears to me to be the case at this point.
Site Sponsor Perry Paolantonio Posted January 19, 2023 Site Sponsor Posted January 19, 2023 (edited) 4 hours ago, Larry Baum said: 6.5K scans actually do seem to be stored in a format that allows for wide gamut colors any scan under 6.5K does NOT seem to be stored in a format that allows for wide gamut colors (all my sample scans when I was first posting here were under 6.5K) I have avoided this thread because, quite frankly, I think you're looking for a problem that doesn't exist and you have yet to post a single image demonstrating the supposed problem. But I need to correct this: The ScanStation's resolution modes have nothing to do with color. They're unrelated. The "modes" in a 6.5k scanstation refer only to the pixel dimensions (and subsequently the speed at which the scanner runs, because lower resolutions mean less data). Inside the scanner, the camera and lens move closer to or farther away from the film, depending on the mode. In a lower res mode, the only difference from a high res mode is that instead of using the entire sensor it's using a crop, and can run at a faster speed. That is, in 2.5k mode, it's using a 2.5k crop of the 6.5k sensor and is capable of running at up to 60fps. In 6.5k mode, the entire sensor is used because the camera and lens are in a different position, filling the sensor with the image of the film, and this runs at a lower speed because - more data. The internal processing of the data, the output file formats, all of that is identical regardless of the resolution. The only difference between the various resolution modes is the pixel count and the speed at which the machine can run. Now, if you're comparing DIFFERENT SCANNERS - say an original 2.5k ScanStation (which used a CCD camera), or a 5k ScanStation (which used a 5k CMOSIS CMOS camera), or a variant with a 4k camera (which I think is still Sony IMX like the 6.5k but a different model), or an Archivist (which technically isn't a ScanStation and uses a different model Sony IMX camera), then potentially you might see some color differences. But those are different machines, not different modes on the same machine. Edited January 19, 2023 by Perry Paolantonio 1
Larry Baum Posted January 21, 2023 Author Posted January 21, 2023 On 1/19/2023 at 9:11 AM, Perry Paolantonio said: I have avoided this thread because, quite frankly, I think you're looking for a problem that doesn't exist and you have yet to post a single image demonstrating the supposed problem. But I need to correct this: The ScanStation's resolution modes have nothing to do with color. They're unrelated. The "modes" in a 6.5k scanstation refer only to the pixel dimensions (and subsequently the speed at which the scanner runs, because lower resolutions mean less data). The internal processing of the data, the output file formats, all of that is identical regardless of the resolution. The only difference between the various resolution modes is the pixel count and the speed at which the machine can run. Well all I can say is the 5k DPX and DNG file samples I got appear to be in a different gamut than the ones I got in 6.5K. All done on the same machine with the same settings as far as I've been told. The 6.5K ones load into ACR or Resolve with noticeably less saturation than the 5K ones. I'm not running the machine myself, but that is what I can say based upon the files provided. I mean maybe something got toggled somewhere somehow. Again all I can go on is the files I got and what I was told. I'm not running the machine and was not there when stuff was scanned. The only thing I can think of is that to produce lower than 6.5K they might need to de-Bayer first (depends upon how it creates lower res) and once they are doing that, maybe they do more processing? Although if what you say is how it generates lower res then that would not seem to be the case, it shouldn't need to de-Bayer first. The metadata for all of them seems to be wrong. They are all stored with a forward color matrix that would make sense for something very close to REC709 gamut. Applying that to 5K files I got looks kind of correct, saturation looks normal, but you do see that there is a weird shift in some colors, red is too orange, some other colors don't balance relative to others (nothing that color temp or tint fix, they can fix one color but then send the other off), maybe subtle at first glance, but quite real in the end. Anyway, the fact that REC709 gamut applied to interpret the 5K files looks remotely normal at all would kinda imply the data is not in native scanner wide gamut but has been pre-processed. Applying the metadata or REC709 to the 6.5K files I got doesn't look correct at all, same as for 5K but also with saturation much too low. If you do large adjustments to Adobe ACR Calibration panel to adjust primary locations you can eventually get it to start doing stuff that looks normal. Anyway, how do you explain the forward matrix in the metadata being so similar to a forward matrix for REC709? Either it's completely wrong (which actually does seem to be the case for the 6.5K files) but in that case why do they put bogus metadata and not metadata that properly describes the gamut the data is stored in reference to? or it's correct and the data is not in native scanner gamut but processed down (As seems, sort of (not sure about the color twist), to be the case for the 5K files I got).
Larry Baum Posted January 21, 2023 Author Posted January 21, 2023 (edited) I can find and show this demo at least to show the metadata for 6.5K files being wrong part at least. The 6.5K metadata says to process files like this as default load: If major changes are applied to the near REC709 gamut by altering the primaries to something like some custom wide gamut mode then people can get it to load more correctly like: With the 5K samples I got it would be like the above only the first image would have about the same saturation as the second as a default load, but with the color tones still like you see in the first image and because of that that is why I was questioning if it was storing native wide gamut or not, since they seemed to load fully saturated when interpreted as REC709 gamut. The 6.5K files I got don't seem to load fully saturated when interpreted as REC709 gamut. Edited January 21, 2023 by Larry Baum
Larry Baum Posted January 21, 2023 Author Posted January 21, 2023 (edited) Anyway all I can go by is what I received and what I was told and how the files are loading on my machine in ACR (and seemingly also Resolve, although I didn't use this too much). Maybe I was told incorrect stuff or something got toggled or there is a bug in ACR or something. All I can say is what I was told and what the metadata in the files and how they are acting. I do agree it would seem fairly strange for 6.5K files to be stored in reference to a different gamut than 5K ones (especially if it didn't have to de-Bayer and downscale to 5K but it seems like it just uses a smaller part of the sensor so that does make it quite strange). I don't know why it should be at all. The 5K (and 6.5K) files have metadata suggesting they are nearly REC709 gamut (although this appears to be wrong for 6.5K files at least, unless the difference is not due to some ACR/Resolve software bug that is for some reason making them load differently) and the 5K samples I got acted like REC709 in processing so that is why I was asking about how you get wide gamut out of this scanner. Now the 6.5K files I got later behaved differently. It does seems strange, but they do. As a bit of a sanity check I was give a tiny new set with 6.5K and 5K and in the new set the two sizes once again behaved differently. Maybe it's a bug in ACR or Resolve. Maybe the scanner somehow hit something different each time for 5k and not for 6.5k. Maybe the scanstation is doing more stuff to the lower file sizes. I dunno. If they truly are both in the same format, than there is some bug in some software on my end somewhere along the line. And then there is the question is the metadata correct or not and is the way they are loading as 5K or as 6.5K on my system correct. In one case, the scanner would not be producing wide gamut output but clipping to REC709. In the other case, at the least, the data output would be stored in some moderately wide gamut format. Loading the 5k samples into RAW software that was told to ignore metadata for color gamut and just pretend the data is stored in reference to REC709/sRGB primaries made them load looking fairly normal (do that to wide gamut format data and it looks all washed out). I didn't try that for the 6.5K files. Edited January 21, 2023 by Larry Baum
Larry Baum Posted January 21, 2023 Author Posted January 21, 2023 On 1/19/2023 at 9:11 AM, Perry Paolantonio said: I have avoided this thread because, quite frankly, I think you're looking for a problem that doesn't exist and you have yet to post a single image demonstrating the supposed problem. But I need to correct this: The ScanStation's resolution modes have nothing to do with color. They're unrelated. The "modes" in a 6.5k scanstation refer only to the pixel dimensions (and subsequently the speed at which the scanner runs, because lower resolutions mean less data). Inside the scanner, the camera and lens move closer to or farther away from the film, depending on the mode. In a lower res mode, the only difference from a high res mode is that instead of using the entire sensor it's using a crop, and can run at a faster speed. That is, in 2.5k mode, it's using a 2.5k crop of the 6.5k sensor and is capable of running at up to 60fps. In 6.5k mode, the entire sensor is used because the camera and lens are in a different position, filling the sensor with the image of the film, and this runs at a lower speed because - more data. The internal processing of the data, the output file formats, all of that is identical regardless of the resolution. The only difference between the various resolution modes is the pixel count and the speed at which the machine can run. Now, if you're comparing DIFFERENT SCANNERS - say an original 2.5k ScanStation (which used a CCD camera), or a 5k ScanStation (which used a 5k CMOSIS CMOS camera), or a variant with a 4k camera (which I think is still Sony IMX like the 6.5k but a different model), or an Archivist (which technically isn't a ScanStation and uses a different model Sony IMX camera), then potentially you might see some color differences. But those are different machines, not different modes on the same machine. Looking at the files more it does seem like the 5k and 6.5k actually were not done exactly the same way. The 5k were exposed a bit more with a slightly different color balance used it seems (although the metadata seems to claim the LED balance was the same so not sure, maybe the color balance difference is because they were processed differently by scanner software at some stage or maybe the metadata doesn't report a difference in how the WB was actually really set or maybe ACR uses a twisted profile or maybe who knows what was done with the early 5K quick demo samples). So until I get some more samples done same time, exact same way for 100% sure, I suppose ignore my last few posts. That said, if I raise the whites to make them look more or less the same exposure wise and set white balance on same white part to get white balance the same, the 6.5K one needs a huge +38 saturation to look similar (tint and colors are still a touch different). Just messing with color temp and tint sliders in ACR, for this one particular image, it doesn't seem to affect saturation too much at all though. Although perhaps the scanner sensor and such is very sensitive to the balance of it's LED lights and how it sees film and maybe it records a lot less saturation if it sends a bit less light through or something and maybe even for this color it would do that even if that color doesn't act like that in ACR? I wouldn't think it should make THIS much of a difference from a bit of an exposure difference and slight, nothing huge, seeming shift in white balance on the scanner to the images overall saturation, but maybe? Anyway, since it seems they actually were not scanned the exact same way, I guess it is better to ignore what I said until I can verify it happens when the conditions truly were exactly the same for the scans. I'll try to get a sample 5K and 6.5K frame absolutely done the exact same way at the same time and see what happens. Maybe something was set weirdly or vastly different the 5k demos frommuch earlier on. Again, it's hard to say not running the machine myself. At the least though there do seem to be the somewhat strange things: 1. metadata suggests the data is more or less REC709 gamut which one would not think should be the case for native scanner output, of course the metadata could be and probably is wrong, but why put in incorrect metadata? data should really be stored in reference to something correctly given so programs know how to interpret it (now sure the data may still need some calibration adjustment after that, but the base starting point should at least be correct) Or if the metadata is correct, how can native RAW from the scanner end up being so ultra close to REC709 gamut? (side note: at least with the way the 5K samples were scanned they sure seem to work and act like they have REC709/sRGB-like data in terms of how saturated the primaries are (although with whatever was done with the 6.5K that doesn't seem to be the case, so it's all strange, trying to adjust exposure to equalize didn't match saturation at all, but ACR might do funny stuff with color engine, etc. etc.)) 2. how come if the DNG are true RAW files it puts the display rather than scene referred flag in the metadata and tells programs to treat them closer to JPGs and TIFFs than real RAW files (for instance ACR gives a points slider for color temp instead of the Kelvin scale, etc.), you'd think true RAW scanner output should be scene referred flag like it is for DSLR RAW images or for most stills film scanner RAWs
Larry Baum Posted January 21, 2023 Author Posted January 21, 2023 (edited) I'm starting to think those initial few quick 5K samples I got maybe had the LED balance on the scanner set in some odd way. Either that or on the new 6.5K files. The thing that makes it tricky is the darn metadata claims same As Shot WB and scene and LED temp for both! But looking into things like colors in sprocket holes that does not actually seem to be the case. So it seems the metadata is likely not reliable at all (which isn't a great thing). And I'm not sure that things actually were scanned using same settings as I thought, so at this point it's hard to know exactly what is going on beyond that the metadata appears likely a false mess for the outputs from Scanstation and that things might actually have been scanned in different ways each time contrary to what I thought, the quick demo frames and bits and the real scans at full res. Anyway, I need to get more info at this point to figure out what the real deal regarding anything going on is. All I can say is the early 5k samples I got behave totally differently (actually closer to how the metadata says they should, but that would be weird if it was supposed to be like that since native scanner data should not be REC709-gamut-like, so maybe something was set weird and it was just a coincidence that it worked closer to the metadata for gamut and the metadata is set wrong) than all new 6.5K samples and scans which all act virtually identically and that the metadata does not let programs give the proper colors for either set, especially not for the 6.5K stuff although doing a lot of manual adjusting of primaries and so on you can get them all looking correct. Edited January 21, 2023 by Larry Baum
Larry Baum Posted January 22, 2023 Author Posted January 22, 2023 Man, I'm starting to think that the initial little batch of a few quick 5K demos I got, that something was set all strangely with them which added a lot to the general confusion along with the seemingly generally bogus metadata in the files. I found another 5K little set that seems to act more like my 6.5K final scans. Who knows at this point after all the confusion, but I suspect it may all come down in the end to: 5K and 6.5K and so on probably will all act the same (which would make more sense) Scanstation probably does scan out data in some moderately wider than REC709 gamut format, perhaps something a trace smaller than P3 (still not 100% sure though and you'd think the true RAW data might be even wider than that, not that wider than that would be needed for film) metadata put out by the scanstation is almost all completely bogus and best ignored, but this also means you need to do some complex type corrections, adjusting primary locations and such (still not 100% sure, but seems likely)
Larry Baum Posted January 22, 2023 Author Posted January 22, 2023 Anyway I need to wait to get another set of files to really tell what is going on. It's hard with potentially bogus metadata and then not being 100% sure exactly what was done and set for each scan. Some things are still not adding up. And the 5K early samples still ended up with relatively similar color balance in the main image area so you wouldn't think anything should have been so radically different in saturation, etc. (sprocket holes have extremely different color temp, optical track area has only moderately different color temp, might just be sprocket clipping after adjustments applied for the way this system can expose each channel on its own, so may not mean so much and would make you think that the 5K set should not act so differently than the other sets)
Peter Andrews Posted March 6, 2023 Posted March 6, 2023 On 11/23/2022 at 11:07 AM, Carl Looper said: The lack of technical documents regarding how ScanStation scans a film when particular setting are applied, and that operators of ScanStations appear to have no idea what you are talking about when talking about colour spaces, means that one is left to hypothesise what the result of a scan might be. In practice, of course, scans can be eyeball adjusted in software such as Resolve, and most colours will be reconstructable through that process. It's when otherwise using a scan of a film print to assess that film print (e.g. ahead of making a better print) that the specifics of the encoding become important. One might very well take a scan through Resolve and make a beautiful digital result from it, but how to otherwise use that grading information to make a new projection print, is entirely lost if a scan house (or Lasergraphics) can't or won't describe the scan in terms of the transforms it uses to encode the scan. That all said, a combination of speculation (hypothesising) and tests of such would eventually solve for such lack of information. Hi Carl, we are in Australia and have an Arriscan XT (The newest model from Arri) and a Xena, a Cintel, and some LG scanners. If you want to shoot a test film, we will happily scan it and post the images for everyone to dissect.
Carl Looper Posted August 31, 2023 Posted August 31, 2023 So I scanned some print film (a test strip) to DNG on the ScanStation. The forward matrix in the metadata of the DNG file turned out to be an sRGB to XYZ D50 matrix: 0.4361 0.3851 0.1431 0.2225 0.7169 0.0606 0.0139 0.0971 0.7142 See http://www.brucelindbloom.com/index.html?Eqn_RGB_XYZ_Matrix.html bottom of page for an independant derivation of an sRGB to XYZ D50 matrix. You can see that the above forward matrix (from the DNG file) is exactly the same as Lindbloom's matrix (if at slightly less precision). The forward matrix in a DNG file should provide a downstream DNG renderer with how to map raw camera sensor data (in the DNG file) to XYZ D50 values (ahead of conversion to whatever colour space the renderer is targeting). To have an sRGB to XYZ D50 matrix as the forward matrix would only make sense if the DNG file contained sRGB values (instead of camera sensor values). Either the camera sensor data has actually passed through a conversion to sRGB, prior to DNG encoding (possible I guess), or the forward matrix in the DNG file is just wrong (perhaps copied and pasted from some default tag set). As an experiment I wrote a low level renderer that took the raw image data from the DNG file, and applied the provided forward matrix to the raw data. I then transformed the supposed XYZ D50 results to sRGB colour space. Eyeballing the results (on an sRGB screen) against the original filmstrip (held in front of the same screen), convinced me the forward matrix must be incorrect. The cyan range in the results were not too bad, but the yellow was way out. A way to determine a more reliable forward matrix is elaborated in this article. https://www.strollswithmydog.com/determining-forward-color-matrix/ Carl
Carl Looper Posted August 31, 2023 Posted August 31, 2023 I should add that if you already know the forward matrix is just an srgb to XYZ D50 matrix, then the experiment is unnecessary, as you will will already know that a subsequent transform, using a XYZ_D50-to-sRGB matrix, will just reconstruct the original values. Which is precisely what happened. But at the time of writing up the experiment, I didn't know the forward matrix was an srgb to XYZ D50 matrix. I just used the forward transform as the required first step in a camera to colour space transform. I just happened to use sRGB as my target colour space, so I could compare the filmstrip against the colours as rendered on an sRGB screen. It was only after doing the experiment that I discovered the numbers used for rendering were the exact same numbers as the original data, i.e that the forward matrix must be an srgb to XYZ D50 matrix. The eyeball test proved the forward matrix was wrong. The identical numbers just proved the the matrix was not a camera to XYZ D50 matrix (unless there is such a thing as an sRGB sensor (ha ha), or that the Sony Presgius is such a sensor (ha ha).
Carl Looper Posted August 31, 2023 Posted August 31, 2023 (edited) In relation to the bigger question regarding whether wide gamut colours are stored, the answer is mostly yes and a tiny no. As far as as a downstream decoder is concerned (such as a wide gamut display) you could feed that display *any* three numbers, and the display would emit a wide gamut light corresponding to those numbers. However the display renderer would only do that if it understands the provided numbers correspond to a wide gamut colour. If a renderer does not know what the numbers represent, it is standard for a renderer to assume the numbers represent an sRGB colour, and to emit light of the corresponding colour. Or when otherwise effectively told (by the forward matrix) that the numbers represent an sRGB colour, it will do the same. If the forward matrix is otherwise updated to represent the correct sensor to XYZ D50 transform (without in any way altering the stored pixel numbers) then a wide gamut display will correctly emit the wide gamut colour of the light that illuminated that sensor. C Edited August 31, 2023 by Carl Looper Clarification
Premium Member Jeff Bernstein Posted September 1, 2023 Premium Member Posted September 1, 2023 “Cinematography.com : the finest minds in world cinema—online for you!” 1
Joshua Echevarria Posted January 4, 2025 Posted January 4, 2025 On 1/21/2023 at 8:03 PM, Larry Baum said: Anyway I need to wait to get another set of files to really tell what is going on. It's hard with potentially bogus metadata and then not being 100% sure exactly what was done and set for each scan. Some things are still not adding up. And the 5K early samples still ended up with relatively similar color balance in the main image area so you wouldn't think anything should have been so radically different in saturation, etc. (sprocket holes have extremely different color temp, optical track area has only moderately different color temp, might just be sprocket clipping after adjustments applied for the way this system can expose each channel on its own, so may not mean so much and would make you think that the 5K set should not act so differently than the other sets) I'm not sure if this is completely relevant to the entire post - I feel like I've been able to understand only a portion of what is being discussed here but I understood your original concern. Below is a note I received when asking about the color space of scanned film that I had done on a scanstation. I was trying to get clarification on the color space so that I could apply a color space transform in Davinci and work in Davinci Intermediate but that is pretty tough to do without the info of the scanned files color space. Anyway, this is what the scanning tech told me - "We've been back and forth about this with Lasergraphics support in the past, and we're told that the colorspace is never really "set" as it all depends on the density of the negative/exposure itself. The only definitive answer we've gotten is that the capture and output should reflect a logarithmic colorspace. Cineon Log has been the standard for some time, and I've been told by colorists in the past that they've used Cineon Log, Davinci WG, and even Arri Log C, it sort of depends on workflow and preference. I believe any wide gamut colorspace should be able to work with the density of these scans, and rec2020 makes sense as the gamma setting as this was a 2-pass capture, but I can't say that with total certainty as I'm not a colorist. " I've tried cineon log and achieved the best results but I guess I'm still curious for a more concrete answer.
Daniel D. Teoli Jr. Posted February 19, 2025 Posted February 19, 2025 I don't get back to the threads very often. I'm busy with other things. I like to let them marinate and see what develops. So, if I fail to answer any replies, that is why. I just scanned all the posts here and still see no comparisons of scan output. I just don't get it. One guy sends in tons of tables and numbers; everything but actual scanner output. Robert sends in a video of this Arriscan running. Great, but where is the output of said Arriscan Robert? Flashing color lights means shit Robert. It is the output that counts Robert. And same to Perry. When you are talking color evaluation you need the same regulated color balance on both ends of the phone. This was very important with graphic arts where it was costly to make mistakes. That is why we have viewing standards. Regulated light viewing equipment. Same with light tables. Everything has to be regulated, or everyone in the conversation won't be on the same page. From GTI: When an item is viewed, the color we see is a result of the color quality of the light source and the reflective characteristics of the item. As a result, when attempting to achieve an accurate color match, colors can appear to match under one light source and then appear significantly different under another light source. Therefore, designers, brand owners, and production staff should all evaluate a color under a consistent light source. To help achieve this goal industries have developed international standards for the viewing of color. The graphic arts and photographic industries have adopted ISO 3664:2009 entitled “Graphic technology and photography– Viewing conditions.” ISO 3664: 2009 specifies D50 daylight viewing conditions. Industrial color applications (plastics, paints, textiles, automotive, etc.) have adopted ASTM D1729-2009 as their standard, which specifies D65 daylight viewing conditions. Now, just sending in raw scan samples is not the end all...but it is a start. It is really sad; you people will go out of your way to send in everything...except images. <><><><> Daniel D. Teoli Jr. Archival Collection Daniel D. Teoli Jr. Small Gauge Film Archive Daniel D. Teoli Jr. Advertising Archive Daniel D. Teoli Jr. VHS Video Archive Daniel D. Teoli Jr. Popular Culture Archive Daniel D. Teoli Jr. Audio Archive Daniel D. Teoli Jr. Social Documentary Photography
Site Sponsor Perry Paolantonio Posted February 19, 2025 Site Sponsor Posted February 19, 2025 1 minute ago, Daniel D. Teoli Jr. said: Flashing color lights means shit Robert. It is the output that counts Robert. And same to Perry. Respectfully, Daniel - you don't know what you're talking about. You keep trying to compare motion picture film to what you know from still photo and while they are both film and there are some similarities, they are different in many ways and the workflows and software used to manipulate the files are completely different. The film stocks are different, and the methods of scanning them are different. You can't compare them.
Site Sponsor Robert Houllahan Posted February 20, 2025 Site Sponsor Posted February 20, 2025 11 hours ago, Daniel D. Teoli Jr. said: Robert sends in a video of this Arriscan running. Great, but where is the output of said Arriscan Robert? Flashing color lights means shit Robert. It is the output that counts Robert. Are the flashing lights in the room with you now? Are there four lights or five? Is there a Cardassian in the room administering to the lights? 1
