John Woosley
Fogging up a backyard
Hey everyone,
I'm going to be shooting some drone footage in a few weeks of a backyard, and the idea is that there would be a layer of fog on the ground to make the setting seem like some kind of alien landing. I'm going to be shooting this in the summer in the US, so pretty warm temp wise, so if I did have a fogger and put it through a chiller would it even lay down in such a hot environment? Whats the best way to achieve this?
Share this post
Link to post
Chilled fog will rise when it heats up. On a warm day its not going to stay cool for very long.
Perhaps if you shoot really early in the morning and get the fog really cold it will stay low enough, long enough to get the shot.
Share this post
Link to post
I haven't tried this but would it work to wet the grass thoroughly so that the surface would cool down a little when the water evaporates and the fog could maybe then stay a little longer?
Share this post
Link to post
Yeah wet grass might help - along with lots of cold fog, that would help cool the ground too.
How are you chilling the fog? I've had pretty good results pumping it through a box of ice cubes.
Share this post
Link to post
On 6/12/2019 at 7:58 AM, Brian Drysdale said:
Dry ice tends to lie in a layer.
Indeed it does, but it can be very expensive. You'd need quite a bit of it.
Share this post
Link to post
Yes dry ice mist tends to lie low close to ground but I would worry about it being white so it can actually be seen in the image as well. If wanting to use dry ice one could first wet the grass and then throw dry ice grains around. Here they sell dry ice either in blocks/chunks or small grains. The grains have been easier for fog effects use for us when needing to throw the dry ice around, no need to crush the big chunks to get usable size bits
Edited by aapo lettinen
Share this post
Link to post
Guest
Reply to this topic...
  Only 75 emoji are allowed.
  • Wooden Camera
    G-Force Grips
    FJS International
    Just Cinema Gear
    The Original Slider
    Cinematography Books and Gear
