Marco Leoncino
Eastman Double-X 7222 16mm home processing
Dear all,
I was making a search in the forums and in the web, in order to find updated information, but I didn´t find what I was searching. Therefore I have opened this new topic.
I have learned how to develop the kodak Tri-X 7266 film and, in particular, the B&W inversion process (with a Lomo tank). Paradoxically, I am thinking to use a negative B&W film, for my future projects, because I need more latitude. I was thinking to process the Kodak 7222 at home, in the Lomo tank.
The question is the following:
is it possible to develop theEastman Double-X 7222 in Kodak D-76, or it is much better to use the D-96?
D-96 is usually used stock, but I guess that D-76 should be used 1+1. Does anyone has some starting points?
Can you please help me?
Thank you very much!
Share this post
Link to post
27 minutes ago, Marco Leoncino said:
Dear all,
According to Massive Dev Chart,
DoubleX in D76 1+1 (ISO 250) should be 10min at 20C
DoubleX in D76 1+2 (ISO 250) should be 12min at 22C
DoubleX in D76 1+3 (ISO 250) should be 20min at 22C
You should get this app, it's the best I know out there for recipes. I use it on iOS but i'm sure it's on android as well.
They also have a website and this is what they have for 5222 in D76
https://www.digitaltruth.com/devchart.php?Film=%Kodak+Double-X%&Developer=%D-76%&mdc=Search&TempUnits=C&TimeUnits=D
Share this post
Link to post
My latest developments using 7222 were in D-76. Low contrast was wanted. Three tests were made. Here is a link to pictures with descriptions. Today I printed the entire roll onto 3378, another set of chemicals and procedures that took 2 tests.
Share this post
Link to post
Dear Michael,
thank you.
With 1 to 2 you mean one part of D76 in two parts of water?
D96 would have caused more contrast? Or which other difference?
Share this post
Link to post
Aside from saving money, a big part of the appeal of home processing would be the option of NOT having to use a typical solvent-type developer (high-sulfite D96, D76 and others) and open it up to experiment with staining developers (pyrogallol or catechol), acutance developers (Rodinal & co.), etc.
Does the tank develop evenly or is there flicker in the moving image?
-Jarin
Share this post
Link to post
Nik and Trick (UK) sell the D96 developer and F6 fixer for that film...made by Bellini
https://ntphotoworks.com/product/bellini-d96-fixer-f5-kodak-double-x-package-deals/
Also....Eastman Double X has little latitude in my experience.....I used it on this personal project and my exposure had to be within like 1/2 stop to be 'on'....this is MY experience with the film.....not saying its universally correct for everyone as I guess depends how you light it etc.
I particularly found that for exterior shots you have to be spot on with the metering esp. in bright conditions with the sun full on. I rated it at 250 iso like Kodak says and for me this is accurate. I lit the main close-ups with a Multiblitz V6 LED light on a rectangular soft box....the bed and shower scenes with the light coming in from an Arri Plus 1000w tungsten and the beach part with bright sun
In my experience, using Double X is like using E6 film when it comes to metering....but what a beautiful beautiful stock it is....
I did this with it....Cinelab London processed and scanned for me.
Edited by Stephen Perera
Share this post
Link to post
Guest
Reply to this topic...
  Only 75 emoji are allowed.
  • Tai Audio
    FJS International
    G-Force Grips
    Just Cinema Gear
    Cinematography Books and Gear
