James Dove
Krasnogorsk-3 Trigger Issue
I've looked through the site and couldn't find another person with the same issue as I have had with my Krasnogorsk,
The camera was working completely fine and then on my next wind the trigger stopped working, I didn't hear the spring break or any unnatural noise so was curious as to what it could be?
I removed the lens to check and can see the trigger moving when I press, but it seems the motor does not engage.
Any help would be greatly appreciated.
Share this post
Link to post
Most probably the spring has sprung from its core, a known issue of the Krassno. You can send the camera to me, I’ll bring that back to order. It can happen anytime again. Long-term remedy: get yourself a better camera.
Share this post
Link to post
I have problem, that my K3 won´t run - literally the gears can not turn.
I disassambled front part, then inner part, so I can see all the mechanics.
Spring is in good order, but when I try to move mirror or main chaft by hand, or by wound crank, I can´t.
And I can´t figure out what is stuck, because every gears seems to be OK, everythink is clean, no evidence of problem inside.
Share this post
Link to post
The trigger on the K3 is kind of clunky. I've had issues with mine as well. If you take the front off and the inside out, you should be able to see the trigger assembly. It's made out of a little thin piece of metal and it can very easily get stuck. That could be why the mechanics won't move, I believe the trigger prevents them from spinning when it's not depressed.
Share this post
Link to post
with Krasnogorsks there is also the pretty common problem of the sprocket wheel jamming against the guide rollers. You can easily check by opening the upper and lower guide roller and then try to move the mechanism again. If that solved the problem then the sprocket wheel needs to be realigned and adjusted (it LOOKS like there is lots of good positions for it but there is only one where it does not jam all the time. it is easy to get it wrong when disassembling the camera)
if that was not it then it may be a larger problem which needs more work.
Share this post
Link to post
+1 on this. Those little flat head screws that hold the guides, they come loose. That whole assembly is garbage and I'm always shocked when it works.
Share this post
Link to post
The same happened to me a few times. I solved the issue by hitting the camera body with the heel if my hand, a good sharp knock on the body, not the door area. Also works when thrown at a person....
Chance of damaging camera? Minimal.
Having a camera that doubles as a weapon? Priceless.
Share this post
Link to post
Thanks All, I tried but failed at fixing it myself, so have taken it in to Sendean Cameras in London to take a look. Will update on what the issue was.
Share this post
Link to post
Guest
Reply to this topic...
  Only 75 emoji are allowed.
  • Rig Wheels Passport
    Just Cinema Gear
    G-Force Grips
    FJS International
    Cinematography Books and Gear
