M Joel W Posted April 30, 2024 Posted April 30, 2024 I bought an adapter from someone on this forum (traded for it) and forgot to see if it fit on my camera. Which I should have. It doesn't quite seem to fit. The three prongs don't go low enough to lock the mount. My other lenses and Aaton adapters are all okay. Should I bring it to a machinist to machine down the sides of the prongs? Which I assume are the issue? Or just sell it here really cheap/give it away? Is this a common issue? Any way to fix it? Thanks!
Robert Hart Posted April 30, 2024 Posted April 30, 2024 Is it by any chance a Nikon F-Mount to CP-Mount adaptor with a small planar glass element inside? Aaton Mount and CP-Mount apparently have some similarity but the Aaton shoulder diameter may be wider.
M Joel W Posted April 30, 2024 Author Posted April 30, 2024 I don't believe so. No glass element inside and it's a very close fit, just feels a little too tight and kind of gets stuck in the mouth and the positive lock won't lock. It fits into an Aaton cap.
Premium Member Tyler Purcell Posted May 1, 2024 Premium Member Posted May 1, 2024 Very odd, I had one that fit perfectly. I wonder if it was somehow damaged. 1
M Joel W Posted May 1, 2024 Author Posted May 1, 2024 It's odd – I measured it with a caliper and everything seems to be about the same as my other Aaton mount lenses, at least close enough. I wonder if just shaving down a little bit here or there might help. But it's hard to say.
Premium Member Dom Jaeger Posted May 1, 2024 Premium Member Posted May 1, 2024 So is it the thickness of the flange wings that is out, so the lock ring won’t turn over them? Or the mount won’t seat properly? On PL mounts, the flange wing thickness needs to be within about 0.05mm of the nominal size for the lock ring to properly lock. Manufacturing errors, a burr or distortion due to being dropped can cause problems. The front surface of the flange wings (not the rear, seating surface) can be lathed down if necessary. There can also be potential issues with the chamfer around the lip of the camera mount and the right angle cut of the lens mount where the rear cylinder goes inside the camera mount. If there is too much of a rounded corner on the lens (or adapter) mount it may not seat properly. I’ve sometimes had to lathe an undercut on cheap PL mounts so they seat properly. Unless it’s distorted a machinist should be able to fix the issue. 1
M Joel W Posted May 5, 2024 Author Posted May 5, 2024 On 5/1/2024 at 1:19 AM, Dom Jaeger said: So is it the thickness of the flange wings that is out, so the lock ring won’t turn over them? Or the mount won’t seat properly? On PL mounts, the flange wing thickness needs to be within about 0.05mm of the nominal size for the lock ring to properly lock. Manufacturing errors, a burr or distortion due to being dropped can cause problems. The front surface of the flange wings (not the rear, seating surface) can be lathed down if necessary. There can also be potential issues with the chamfer around the lip of the camera mount and the right angle cut of the lens mount where the rear cylinder goes inside the camera mount. If there is too much of a rounded corner on the lens (or adapter) mount it may not seat properly. I’ve sometimes had to lathe an undercut on cheap PL mounts so they seat properly. Unless it’s distorted a machinist should be able to fix the issue. Thank you! It might be the chamfer. It's so close to fitting. I'll probably take it to machinist when I get back to LA.
Premium Member Stephen Perera Posted June 11, 2024 Premium Member Posted June 11, 2024 My Nikon to Aaton mount adapter is quite crap in that it's loose.....Les Bosher told me to do something which I can't remember cos I just use my Cooke zoom lens all the time
M Joel W Posted June 12, 2024 Author Posted June 12, 2024 (edited) 11 hours ago, Stephen Perera said: My Nikon to Aaton mount adapter is quite crap in that it's loose.....Les Bosher told me to do something which I can't remember cos I just use my Cooke zoom lens all the time Thanks. So it's interesting, I tried two more adapters out (sold by someone on this board who was very helpful) and apparently they're genuine Aaton adapters. But one is newer, one is older. The older one looked like the one I have that didn't fit. It also didn't fit. But apparently it fits most other Aaton mount cameras. Mine is an older camera (LTR-X). The newer one looked different and it fits my camera well well. It's not too loose, either. If you're interested in trying my old one out to see if it's better I'm selling it really cheap. Edit: probably not worth the effort if you're in Europe; I'm in the US. Edited June 12, 2024 by M Joel W
Premium Member Stephen Perera Posted June 12, 2024 Premium Member Posted June 12, 2024 Thanks but I never use Nikkor lenses adapted. I've never come across Nikkor 16mm lenses and thus I only use my Cooke lens and M42 mount lenses I have....eg the Pentax Takumar 200mm M42 mount is superb as an adapted lens on the Aaton.....
