Allyn Iwatsuru Posted May 14, 2021 Share Posted May 14, 2021 I successfully converted this Meike 3.5mm fisheye to c mount by frankensteining multiple other mounts together. I always wanted a fisheye for 16mm but my only options have been limited to a select few rare lenses that are also quite expensive, but this Meike caught my eye. I had always wondered if converting m4/3 to c mount was possible due the longer focal flange distance so I bought the lens and for $180 I figured I couldn't lose. IMG_8031.HEIC IMG_8073.HEIC 1 Quote Link to comment Share on other sites More sharing options...
Allyn Iwatsuru Posted May 14, 2021 Author Share Posted May 14, 2021 5 Quote Link to comment Share on other sites More sharing options...
Philip Forrest Posted May 15, 2021 Share Posted May 15, 2021 This is pretty cool. How close does the rear element shroud get to your prism? Phil Forrest Quote Link to comment Share on other sites More sharing options...
Allyn Iwatsuru Posted May 15, 2021 Author Share Posted May 15, 2021 19 hours ago, Philip Forrest said: This is pretty cool. How close does the rear element shroud get to your prism? Phil Forrest Not that close, the shroud sits almost flush with the barrel of the mount and the mount isn’t the full length of the c mount threads. Quote Link to comment Share on other sites More sharing options...
Patrick M P Donnelly Posted May 24, 2021 Share Posted May 24, 2021 There are 4.8, 5.5, 6 and 6.5mm c mount lenses available on fleabay. All but the 4.8mm are for 1 inch sensors, close to S16mm. The 4.8mm is on its way to me and may be for 1 inch. The distortions are impressive, but the 6.5mm is almost tolerable. The best rectilinear, moderately affordable, extreme, wide angle lens in C mount, is the Kowa or Navitar 6mm HC series. Some second hand ones have wandered onto our fave electronic flea market. There appear unused. Some seller has compiled all the available video demonstrations of this lens, in the advert. Modesty forbids... Brand new, the Kowa actually have a wider lens: 4.7mm F/2.4 for a mere $1,079 AUD. Unknown how it draws. Quote Link to comment Share on other sites More sharing options...
Marc De Acetis Posted July 29, 2021 Share Posted July 29, 2021 Looks so cool! What adapters did you use to finally get to C-Mount? Quote Link to comment Share on other sites More sharing options...
Allyn Iwatsuru Posted September 19, 2021 Author Share Posted September 19, 2021 On 5/23/2021 at 8:22 PM, Patrick M P Donnelly said: There are 4.8, 5.5, 6 and 6.5mm c mount lenses available on fleabay. All but the 4.8mm are for 1 inch sensors, close to S16mm. The 4.8mm is on its way to me and may be for 1 inch. The distortions are impressive, but the 6.5mm is almost tolerable. The best rectilinear, moderately affordable, extreme, wide angle lens in C mount, is the Kowa or Navitar 6mm HC series. Some second hand ones have wandered onto our fave electronic flea market. There appear unused. Some seller has compiled all the available video demonstrations of this lens, in the advert. Modesty forbids... Brand new, the Kowa actually have a wider lens: 4.7mm F/2.4 for a mere $1,079 AUD. Unknown how it draws. I looked into those and they probably turn out great results, but are a bit expensive for me. On 7/29/2021 at 6:49 AM, Marc De Acetis said: Looks so cool! What adapters did you use to finally get to C-Mount? Sorry I never got back to this question. Here are the links to the adapters. https://www.bhphotovideo.com/c/product/1245026-REG/fotodiox_c_mft_lens_mount_adapter_for.html https://www.bhphotovideo.com/c/product/889270-REG/computar_VM400_Extension_Tube_5mm.html Quote Link to comment Share on other sites More sharing options...
Raymond Zrike Posted May 2 Share Posted May 2 Those results look fantastic! Not sure why I had never seen this thread before you mentioned it elsewhere. On 9/18/2021 at 8:53 PM, Allyn Iwatsuru said: Sorry I never got back to this question. Here are the links to the adapters. What process did you take to combine the C-to-M4/3 adapter and the extension tube? Did you manage to keep infinity focus (although that isn't much of a concern for something so wide)? Quote Link to comment Share on other sites More sharing options...
Allyn Iwatsuru Posted May 3 Author Share Posted May 3 5 hours ago, Raymond Zrike said: Those results look fantastic! Not sure why I had never seen this thread before you mentioned it elsewhere. What process did you take to combine the C-to-M4/3 adapter and the extension tube? Did you manage to keep infinity focus (although that isn't much of a concern for something so wide)? Literally just glued the two adapters together hahaha, the c mount extension tube screws into the m4/3 adapter so you don’t have to worry about centering it. Drilling holes for screws would be simple enough and I would do it if I was adapting a more expensive heavier lens. The new mount does actually allow for infinity focus (a little closer, maybe at the 7ft mark off the top of my head) because it’s the adapter flipped upside down so it’s essentially just a m4/3 mount with c mount threads. The reason why it doesn’t hit infinity perfectly on mark is cause I had to file some of lips away thus making it closer to the film plane. Quote Link to comment Share on other sites More sharing options...
Raymond Zrike Posted May 3 Share Posted May 3 Very interesting. If it’s that simple, maybe I could just smoosh together a m4/3 mount and a c-mount in Blender or something and send it off to a 3D printer. I’d have to learn Blender first lol, but anything for art! I’ll give your method a shot first though. I think the difficult part would be maintaining the accuracy of the focus scale, but personally I just focus through the viewfinder, so this could be viable for some shooting situations. Quote Link to comment Share on other sites More sharing options...
Allyn Iwatsuru Posted May 4 Author Share Posted May 4 On 5/2/2022 at 6:06 PM, Raymond Zrike said: Very interesting. If it’s that simple, maybe I could just smoosh together a m4/3 mount and a c-mount in Blender or something and send it off to a 3D printer. I’d have to learn Blender first lol, but anything for art! I’ll give your method a shot first though. I think the difficult part would be maintaining the accuracy of the focus scale, but personally I just focus through the viewfinder, so this could be viable for some shooting situations. I entertained the thought of finding a metal shop to fabricate some adapters since I had got a lot of interest from friends of friends, but after short research I found that metal shops typically only do large quantities. That idea was killed quickly. I wouldn’t worry about the focus scaling marks it’s a 3.5mm, if it hits infinity practically everything is in focus Quote Link to comment Share on other sites More sharing options...
Raymond Zrike Posted May 4 Share Posted May 4 I believe 3D printing services are a bit different than a metal shop—from my little bit of research, it seems you can get a small quantity or even just one printed. I was looking at one printing service and they quoted $12 for an aluminum print. I have another part that I want printed for my Eclair ACL anyways, so I’m going to get that made first and see how it goes. Then maybe will do the c-mount to m4/3 mount! Quote Link to comment Share on other sites More sharing options...
Antoine Pret Posted May 4 Share Posted May 4 That is so good ! Thanks for sharing ! Quote Link to comment Share on other sites More sharing options...
Allyn Iwatsuru Posted May 4 Author Share Posted May 4 Btw to get it to fit on any camera you have to file down that skirt on the rear of the lens body, but on the acl you have to file down a significant amount or it hits where it starts to protrude out for the base of the camera below the lens mount. I’ve fit this lens on a bolex, eclair acl ii and a Beaulieu 2008s. The eclair is the hardest to work with because the handle and the kinoptik viewfinder can be in frame so you have to rotate them back. Quote Link to comment Share on other sites More sharing options...
