Premium Member Phil Rhodes Posted September 16, 2022 Premium Member Share Posted September 16, 2022 I may have to shoot a timelapse of a flower which needs to start off fairly undeveloped, bloom, and wilt. This'll take - what - a good week, I'd have thought? The finished sequence probably only needs to be under a minute, which is 1440 frames; assuming a week that's a frame every seven minutes, though I'd be keen to shoot more than that if I can find a big enough flash card, then things which may happen unexpectedly quickly will still have enough frames. This is likely to involve something like a Canon 7D. Needless to say, I'll need to set things up with mains power, completely consistent lighting, lenses that don't suffer iris bounce, and as much physical stability as possible - and resist the urge to poke at it. I've shot some timelapse before, but mainly sunrises and things that take only a few hours. Naturally, given the time involved, I'm keen not to make too many schoolboy errors. Any advice gratefully received. Quote Link to comment Share on other sites More sharing options...
Stewart McLain Posted September 17, 2022 Share Posted September 17, 2022 I would do some research on the life cycle of the specific flower species that you will be filming and make sure that you are truly looking at a time span of a week. Maybe have a plan to accelerate its demise if necessary. Quote Link to comment Share on other sites More sharing options...
Albion Hockney Posted September 17, 2022 Share Posted September 17, 2022 ask david attenborough Quote Link to comment Share on other sites More sharing options...
Premium Member Adrian Sierkowski Posted September 19, 2022 Premium Member Share Posted September 19, 2022 I wonder if something with an electronic shutter might not be better as there are no real moving parts? Quote Link to comment Share on other sites More sharing options...
Premium Member Phil Rhodes Posted September 19, 2022 Author Premium Member Share Posted September 19, 2022 On 9/17/2022 at 5:22 PM, Stewart McLain said: I would do some research on the life cycle of the specific flower species that you will be filming and make sure that you are truly looking at a time span of a week. Maybe have a plan to accelerate its demise if necessary. That is a good idea. I'd like to see it open up from its supplied state, which will require it being in water, but if I can drain the water (without moving the flower!) it should then wilt fairly quickly. 37 minutes ago, Adrian Sierkowski said: I wonder if something with an electronic shutter might not be better as there are no real moving parts? Possibly, although we're sort of in a "we've got what we've got" situation. Quote Link to comment Share on other sites More sharing options...
Premium Member Adrian Sierkowski Posted September 21, 2022 Premium Member Share Posted September 21, 2022 You are of course welcome to my Fuji if you need. Quote Link to comment Share on other sites More sharing options...
Piotr Wołoszyk Posted September 21, 2022 Share Posted September 21, 2022 What do you mean "big enough flash card"? I'd rather use laptop or something to control the process, trigger the shutter and download files directly from camera. Quote Link to comment Share on other sites More sharing options...
Mark Dunn Posted September 21, 2022 Share Posted September 21, 2022 3 hours ago, Piotr Wołoszyk said: What do you mean "big enough flash card"? I'd rather use laptop or something to control the process, trigger the shutter and download files directly from camera. Yes, I would also shoot this tethered. Sony has a piece of control software called "Imaging Edge", I'm sure Canon has one too. When I'm in the studio I use tethered for anything over, say, 50 frames, that's the breakeven in effort Everything goes down a USB lead between camera and computer straight into Adobe Lightroom if you have it. Something like the 7D will may copy to card anyway, I don't know, but it wouldn't hurt as backup. I don't know what your stills knowledge is so it's hard to say more. Quote Link to comment Share on other sites More sharing options...
Premium Member Phil Rhodes Posted September 21, 2022 Author Premium Member Share Posted September 21, 2022 I've never felt the need to tether anything and I'm honestly not that sure the original 7D will do it with modern software, but I'll certainly look into it. Quote Link to comment Share on other sites More sharing options...
Mark Dunn Posted September 21, 2022 Share Posted September 21, 2022 3 hours ago, Phil Rhodes said: I've never felt the need to tether anything It really is a tremendous timesaver with hundreds or thousands of files. But as you say you've done timelapse before maybe you don't see the need. This says the 7D will do it https://photography-on-the.net/forum/showthread.php?t=832015 I even used freeware originally. The 7D has been at the top of the tree for a long time so I'd be surprised if you couldn't. As I said it depends on the software, but if you're using Lightroom it will import all your images, apply develop presets and make previews on its own. Quote Link to comment Share on other sites More sharing options...
