Josh Gladstone
DIY Film Scanner (With Samples)
They say, a picture is worth a thousand words. Well I say a video is worth 10,000 words. Here's my first attempt at HD Youtube from my iPhone video, not bad for first try.
Tremendous progress yesterday, learned to write code for Arduino, have the Hall sensor triggering the light and soon frame capture on my machine vision camera which is slowly making it's way thru the postal system. This is pretty cool and am very impressed with the Arduino uControllers, I still have lots to learn, but it's fun. COOL! :D
I have an Allied Vision machine vision camera on the way, it's a 2500x1500 pixel camera that can take 4 FPS at that resolution, has remote trigger capability as well as capture thru the software. I am still working on the macro lens arrangement but won't be able to do much until the camera gets here.
Enjoy
https://www.youtube.com/watch?v=ZYYnS2sfhAw&t=
Edited by Paul Robertson
Share this post
Link to post
Very cool. If you want, PM me, and I can share some code with you for controlling an Arduino from custom software. When I was using an arduino to control an Imagica 3000V film scanner that I gutted, I built a custom app using Xojo (RealBasic). The camera had a companion control board and an API for taking the images, and my software would send commands to the Arduino as simple human-readable phrases over a USB serial connection. Such as "Advance1Frame". The arduino basically just listens for incoming commands, does its thing and returns a response. It should work with any software that can communicate over serial connections.
In my setup, there were stepper motors and a ton of sensors, but the basic idea would be the same for yours, with some modifications.
I'm in the midst of another film scanner build right now and got a 100W RGB LED COB to experiment with. Can't wait to see how bright that thing is. It's a monster.
Share this post
Link to post
Hi Perry,
Well that sounds awesome, I will PM you for a little code guidance thanks. I have been studying the libraries and code reference page for the last 2 days, getting my head around it, a bit, but still a ways from getting something communicating. My Allied Vision software is installed but it won't open up firewire until the camera is connected and the camera is still within the postal system.
Today I will try to get something working over the serial lines to confirm I can make it work. I would like to implement your code in there as well.
Now, that 100W COB LED, that will be a monster. I contemplated some of those for my new shop lighting, but chose to use the same ones I am using for this telecine project, as I found them in bulk for $.45 each. You sound like are quite technical as well, but if you need any help with heatsinks for that beast, let me know. For sure a fan based cooling system, big heatsink etc. Look forward to hearing and seeing more about it.
Chat soon.
Cheers
Share this post
Link to post
This probably isn't noteworthy for the rest of you, but it's been a bloody wreck of a week here, -23C with -50C wind chill, all we can do to keep the house heated and the cats warm.
But today, a landmark day in the project, OSCAR has arrived, and I connected him to the computer and low and behold, my $50 take a chance on an "as is" camera, worked out, it works, and what an amazing camera!!! It came with a C-nikon adapter, and I just happen to have about 12 Nikon lenses as that was my film camera system, put everything together and updated the firewire drivers and Shazamm! We have a beautiful image from it, or should I say images, it streams beautifully. You can see the camera at the bottom, bunch of proto wires on the left, computer monitor on the upper right....cool. And that is ony 1280x960, on 2558x1900 the wires completely fill the screen.
Anyway, there are a TON of settings I need to got thru, then get my Schneider enlarger lens mounted on it, and wait for the wonderful old school Soligar bellows to arrive.....
Lots still to do but it's coming together.
WOW!
Share this post
Link to post
Well another big step forward today.
I dug into the software for the camera and technical manual and figured out which pins are the external trigger, then modified my Arduino code to drive a TTL pulse for the camera, sync'd to the magnet on the shutter wheel, and YES! It captures frames perfectly, currently saving them as 2M TIFF files but I can set it for just about any format. I ran it up to about 3 fps and it captures just fine. It's going to take a lot of drive space to digitize all the reels I have. :unsure: I still need to re-read the software manual, I think there may be a way to have it record frames into a video file of sorts, not sure. Otherwise there are many ways to stitch all the image files together. And the Allied Vision software has all of the color correction and gamma and gain and brightness and WB all available to set automatically if I choose. Cool! Just not sure if it will be able to keep up with 2 or 3 fps. I may just lock it in and do all that in post.
Just wanted to update you on the progress. Still waiting for some critical optical components to arrive, but it's coming together nicely.
Cheers
  • Upvote 1
Share this post
Link to post
You can use it to make all the individual frames into a single video clip. Make sure you have all the images in order in the same folder. When in resolve, it will see the images as one video, you can output to any number of video formats.. The program has a rather high hardware requirement, but the free version is very capable.
Share this post
Link to post
Thanks boys, I will try ImageMagick and Resolve, which Perry also recommended, and see which one I prefer. I currently am using VirtualDub, which seems to work fine, but always willing to try other options.
For whatever reason, which I can't figure out, I can't get the Allied Vision capture software to capture in debayered RAW, but it will output decent TIFF files in many formats, YUV422, RGB8 etc. but it would be nice to get the full 12 bit resolution out of the camera. I still need to do some more reading and testing of the software. I picked up a new belt for the projector so I can now continue testing.
The first film I have processed turned out okay, way better than our original dubs we did with the video camera shooting a white screen back in the 90's. I am using Film9, which is a basic GUI that uses AviSynth scripts and VirtualDub and seems to do a decent job. It has saved me from learning yet another code, (will probably have to some day if I am going to perfect this). It's really easy to overdo the settings so I am going to go back and try again with more subtle processing. To test, I am using films that I found at a thrift store, bought them for $4 as they were all loaded on a nice 400' metal reels in cases with a portable steel case, however I have no idea what camera was used or what the film stock was. It seems pretty well exposed and has some good challenging scenes with snow and lots of variety. Funny watching someone else's home movies, they seem to be all from the late 60's.
All of the optical components are hear now as well so I can complete the mechanical side of things, biggest challenge is building the stand to mate the projector to the camera and bellows with enough adjustment for image size and focus.
I'll post some pics and describe the final project after I perfect the design. It's been a lot of fun building this and learning many new things. I am an electronics tech, not a cinematographer so there is a lot to learn about that side of things, optics, colors, formats etc.
Cheers
Share this post
Link to post
Resolve is a Swiss Army Knife of video production and one of the kings of color. Definitely worth getting to know and awesome for the price (free!) and even the $299 full version is so very worth it.
Share this post
Link to post
So I downloaded both programs and discovered there will be a HUGE learning curve for me, on either, so I have continued working with the Allied capture software, and installed a new graphics card, overclocked my PC and now at least I can process a bit faster. I also managed to get the latest Allied Vimba software working correctly, and can now save RAW16 debayered TIFF files at about 2 fps, damn things are 30MB each file so will need about 900GB drive space for one 400' reel, going to be a L O N G process to get all of these reels processed. I have 6 of these 1T drives in the computer but most are half full.
Also finished the mechanical side of the project, and it works awesome, all 1/4" plate aluminum with fine thread adjustments...I will post some pics when I get around to shrinking the files to fit the 300K limit of this forum.
I have made a couple of preliminary tests of capture images, processing with Film9, and saving as H.264 type files, and the results are amazing, can't believe how good it looks compared to the original copy.
Now one thing I found out today, I need to correct the image capture coming right out of the camera, before I even process it, and found it's a tricky balance between Gamma and Black level, probably easy for those of you that have been doing it for years, but for me, new concept.
Is there a preferred ratio, or way to setup gamma vs blk lvl? The image looks pretty good with gamma set at max (1) and blk level at 0, looks a little better with gamma at .5, and blk lvl at around 125 to 150. I know these numbers are arbitrary but would appreciate some guidance. I have over 40,000 hits in a google search so will do some more reading as well about this.
Anyway, that's the update for now.
Cheers
Share this post
Link to post
I think it'll be well worth your time to learn Resolve. It's actually not as steep a learning curve as you think - it's divided into different windows, and for your purposes you'd only use the Media window to load in files, the Edit window to set up a timeline, the Color window to do color work and the Deliver window to export. You can completely ignore Fairlight and Fusion. While it may see overwhelming, it's worth it, and there are a ton of videos out there on basic Resolve use. I'd highly recommend spending some time with it. Because...
Working with 16 bit files is insane. The camera isn't 16bit, and those files are going to be impossible to deal with in a meaningful way. If you can manage to get a CinemaDNG RAW sequence out of the camera, it'll load up in Resolve, which will do the debayering, and a 4k 12bit CinemaDNG sequence requires about the same bandwidth as a 10 bit 2k DPX. That's more than 4x less data to have to store and move around. Believe me, 16bit isn't worth it. (and if you're making 8bit TIFFs, then you're losing a ton of color information from the get-go)
I think trying to do any color correction in the scan doesn't make sense either, because you don't have proper monitoring or scopes. You're best off using a simple histogram to ensure you're not clipping or crushing anything in the scan, then deal with the color in the color/NLE system of your choice.
Share this post
Link to post
Hi Perry,
Well you have pulled me from the digital ditch and I appreciate the guidance. Okay I will dig into Resolve and learn it. I have been working with Allied tech support trying to get the images out of the camera correctly and I now have it working very well, although my only options for outputting debayered images are 8 bit or 16 bit, which as noted are insanely huge files. I know I can output RAW16 files, I will have to try it to see how big they are. Again the Allied camera although is 12 bit, I think will only output 8 or 16 through their software so I may have to rethink the whole capture process, I was really hoping to avoid learning another machine language so I can use OpenCv or one of the other capture programs. I will ask Allied this morning, he is in Germany but is still there right now if there is any way to get just 12 bit images through their software.
I found a site in my search for gamma and blk lvl that referred toCinemaDNG, I'll go back and dig into that a bit more as well.
Now finally, gamma and black level, could you please give me your 1 minute lesson on it? I am still reading about it on the web, but I think your input with regards to film capture may be more relevant.
Thanks again!
Cheers
Share this post
Link to post
So I had a bit of a mental setback yesterday, got frustrated with myself in that I couldn't figure out how to run scripts in a windows shell, get any RAW data converted to TIFF or other usable formats, get Resolve working properly or ImageMagik (couldn't get command line stuff working) so I thought I would take a break and do some more reading.
In the meantime I have discovered that with the Allied Vision camera capture software, there are limited formats in which I can capture frames and I am now thinking I may have to ditch Allied software and go with OpenCV or ??? to do the capturing in the most efficient way, which of course means learning yet more stuff.
Here is what the Allied software can output. The camera is native 12 bit.
RGB 8 bit
YUV422
TIFF 8 or 16 bit
RAW 8 or 16, in 16 bit mode, 4 MSBs are written as zeros
The software can't output a RAW 12 bit, or any 12 bit image. This is why I am wondering if I might be better off using a different capture method. ??
I can output the RAW16 files just fine, which are about 10M each, certainly managable, I just can't get anything to work to get them to an editable format like TIFF or DNG etc.
What I have used for my first attempt at a compete film, is saving RGB8 as TIFFs, about 5M file size each frame.
Here is a link to one of those files, as it came out of the camera.
https://www.dropbox.com/s/tf1rr505k7vqbtg/FILM%201%20196500461.TIF?dl=0
I used these 29,000 frames to make a 15 minute finished product, using Film9 which uses VirtualDub and AviSynth for processing, and even though it is WAY better than what we had with the project and scan from 10 years ago,I think it can still be better, particularly in the black detail and color depth.
Would appreciate your input on what you think of the quality. Maybe I am trying to hard for perfection.
Here is a frame from the finished film.
https://www.dropbox.com/s/6b810a93w27mccs/00761.tiff?dl=0
In the meantime, I am going to continue trying to either figure out another capture method, or a way to get RAW converted to a usable format.
Any and all help greatly appreciated.
Thanks!
Share this post
Link to post
Not sure is anyone is following this thread anymore but thought I would add another update with some samples of what I have achieved so far. Unfortunately the clips aren't as good as the original as I split them using Movie Maker :blink: :rolleyes: ( still haven't learned Resolve)
Would appreciate your thoughts on the quality so far. The clips are all from 1965. Yup, that's me, the little 2 year old kid.
https://vimeo.com/321419125
https://vimeo.com/321420393
https://vimeo.com/321422403
Share this post
Link to post
Looks pretty respectable to me. Sorry if you've mentioned it, but what are you using for stabilisation?
Share this post
Link to post
Hi Phil,
Thanks for the reply.
Stabilization of the images are taken care of in Film9 as a GUI, using VideoFreds scripts for AVIsynth. I just couldn't handle learning another code this winter and found Film9 a pretty easy to use interface. I am getting some pretty incredible results, it's almost like being in the room back in the 60's at some moments. When my Dad got the exposure just right on the old Eumig back in the 60's, it really shows what this puny little 8mm film is capable of, it just blows me away how clear some of this material is.
I have learned so much in the last few months, it's incredible. And I have seen the image you posted a few posts back of the macadam ellipse, on several different web sites, I am slowly getting a handle on light, colors, exposure and such. It's a whole new world for me, optics that is, electronics I have been involved with my whole life.
Cheers
Share this post
Link to post
I see - I haven't had much contact with Film9 but it seems to be much the preferred approach.
I wrote an article recently about the fact that modern transfers of old film can make the film look better than it ever did. It's even true for 35mm, which generally looks much better when transferred straight from the negative (or a closely related element) to a 4K release than it did even in the cinema. Modern technology is really buffing up older stuff nicely. I think what helps Super-8, even if you choose not to degrain it, is the stabilisation. S8 registration was never great and that affected everything.
Have you seen some of the stuff that was shot more recently on the 50ASA daylight negative on super-8? It's on YouTube somewhere. The lenses start to let it down, as they often weren't wonderful on S8 cameras, but otherwise it looks like bad 16mm.
Share this post
Link to post
Well for me it was a way to get transferring without the learning curve of AVIsynth code. I learned Arduino so I could program the microcontroller, but really didn't want to learn another code. My parents are aging and I want to be done this process while they are still able to enjoy these films.
You hit the nail square on the head. I have never seen these films look so good (and they are regular 8). I have watched the ones I have processed a few times and just can't believe the details I can see in the images, things I have never seen before, even on the good Bolex projector. They quite honestly have the quality of HD video, but remain faithful to the film, it still has film quality, just better. Could you post or PM the link to your article?
I haven't seen that, but once I get this project completed, I plan to get all my super 8 cameras going, and start shooting S8 again, after a 30 year hiatus. I have a 4008 and 5008 that I have never put film in, a Canon 814 I forgot I had and a Nuzio and Braun on the way. Planning on Ektachrome (and developing myself). Also try some B&W negative as well. I still have all my dark room stuf, just need to find the S8 pancake processor canister. Another fun project.
Share this post
Link to post
Guest
Reply to this topic...
  Only 75 emoji are allowed.
  • Ritter Battery
