Taylor Bickel
C Stand Heads Won’t Tighten
I work a lot with a guy who has really old Norms C-Stands. The grip heads seem to be looser and looser after every job. You really have to tighten them down a ton. Is there any way of bringing these old heads back to their former glory, or do we just have to buy all new heads?
Share this post
Link to post
The old Matthews ones I have use a cork wafer/friction washer. You could add that if they needed it. Make your own washer out of cork from the auto parts shop if you can't find them. Same stuff as used for valve cover gaskets etc.
Share this post
Link to post
Use contact glue to attach the cork- I think you may know it as contact cement. The stuff you leave to get tacky before joining the surfaces.
Share this post
Link to post
I didn't glue mine. Meant to add that the gasket material was about 2mm (1/16"). I just looked at the Matthews parts store and these washers are $10/ each. 2-1/2' and 4-1/2' sizes available.
Edited by Gregg MacPherson
data error
Share this post
Link to post
Gosh, $18 is really cheap for the head. But consider these thoughts..
-The older brand C stands can last a very long time. They may be worth repairing or maintaining.
-Replacing the cork washer is a maintenance issue, that any head may need.
-The cork sheet is very cheap and cutting to shape is very easy.
  • Upvote 1
Share this post
Link to post
POS made in China.  Looks like a poor copy of an American Grip head.  Many complaints about not tightening or staying tight, etc, etc.  Look at what most lighting and grip houses send out, that's hardware that lasts.
Share this post
Link to post
I mean I've hammered nails with these and they still work well. I prefer them to Matthews gripheads because the tightening handle is ergonomic for my big hands.
How many years do we need our grip heads to last here?
Share this post
Link to post
Gripheads, with minimal care and maintenance, since they are cast Al, should last virtually forever.  Were that not true you wouldn't see used but fully functional American Grip, Matthews, Modern, Norms and even Mole gripheads for sale. Impact gripheads will be in the scrapyard.
Share this post
Link to post
Guest
Reply to this topic...
  Only 75 emoji are allowed.
  • Wooden Camera
    G-Force Grips
    Just Cinema Gear
    FJS International
    Cinematography Books and Gear
